Beocenter 9300 display
Hi all, i have a beocenter 9300 and the display on FM shows a different frequency from the one i am tunning, is there a way t adjust that? Thanks for any help
Hi and welcome to Beoworld! You probably need to adjust the 'FM offset' - quite common if the set has been serviced and the tuner section disconnected or the microprocessor disconnected from the backup lithium battery. The process is explained on pages 5-1 and 5-2 of the Service Manual, which is available on Beoworld to Silver and gold members.  It is probably worth replacing the lithium battery before adjusting the FM offset, as explained here:
