B&O Radio and B&O app 7.5.1.260424517
Good afternoon, guys)) The logos of radio stations in B&O Radio have disappeared in the B&O App version 7.5.1.260424517 on Android 14. This bug occurs when any radio station from any region is enabled. I contacted B&O technical support, and they replied that they could not reproduce the issue. I decided to ask you - if you use the stable version of the B&O app 7.5.1.260424517, please let me know if you've encountered a problem where the logos of radio stations are not displayed. Here are some screenshots for example. However, this issue occurs with any radio station. On the other hand, Spotify works correctly. All the images are displayed as expected. I encountered this bug after updating to the latest version. I would greatly appreciate your feedback to determine if this is a common issue or just my personal problem.
Its best to connect with B&O support in this case.
It won't be much help to you, but they are working fine on Apple IOS - similar 7.5.1 ... app version. Hopefully someone with Android can chip in!
Thank you)) I would be very grateful if those answered me  those who have  Android, I have Android 14 and who do not use beta versions of updates, but the stable latest version 7.5.1.
I have version 7.5.1.260424517 on Android 16, and it works fine.
Thank you, Stan)) So do you have all the logos (pictures) of radio stations in B&O Radio displayed correctly?
Yes, all the logos show. I will try with an older phone tomorrow.
I would be extremely grateful)) Several of my friends who use Android have had the same problem.
I have now tested with an older Samsung Note2o running Android 12 and the latest B&O app, and it works fine (sorry).
