B&O App version 5.90
Hello, Installed and noticed that all sources previously available in my NL/ML converter have disappeared. So immediate roll back to previous version. Regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
B&O have done a shit job on the app since about v5.3. It's been going on for many months, maybe even a couple of years. I lost track. I don't understand how such incompetence can persist in a supposedly 'high end audio' company. I don't think they even test the beta updates of the app. They just fire them out to loyal customers with Test Flight, who have to suffer the endless frustration. It's disheartening to read the reviews of the B&O app in the Apple App Store. If I had read those before I had invested in a B&O system, I would probably have gone with Sonos!
Same thing for Theatre:
Pretty annoying - especially, when you know that the Source List previously was pretty crippled. This in one step backwards, again. I did report that…..every beta tester should! I know that this is beta! However, that should not have happened 😠 Hopefully they will get it sorted soon, otherweise you can roll back to the previous version…..or use the regular version. Alternatively you can - as I prefer - use the BROne (at least for the BS Theatre) MM
After further checks: - no source selection on Theatre, Beosound 1 and NL/ML Converter. - sources selection available for Beosound Core. Already reported through the app. Yann.
On Theatre there is a difference between short press and long press by the Listening Positions and the Sound icons…. …in case you haven’t noticed. However, there was no explanation that this is so. MM
By the way - if this can be of any comfort - the troubles we have with the app changes, is nothing compared to the trouble, that Sonos users apparently have with their new regular app after the update. MM
Sonos ? Not the same price tag …
Endodontist !
On YannChris said
After further checks: – no source selection on Theatre, Beosound 1 and NL/ML Converter. – sources selection available for Beosound Core. Already reported through the app. Yann.
Confirmed. I have a relatively simple system, just a Core and Halo with wired Beolab 1 speakers. B&O app v5.90 seems to work as it should. Stephen
Correction. The search function in Deezer no longer works. All I get is an error message. It was clearly too much to expect that the new version of the app would function as it should.  Back to v5.8.
Attachments (1)
