Added additional NL/ML converter to system - Part 2
For my main ML system I have this NL/ML Converter set up
My additional ML system with its own NL/ML Converter, connected to a Beosound Overture, has this setup.
This leads to the following sources visible on the ML network.
This allows me to play the NL sources on the Overture but I have to prefix the command with AV. I cannot play any of the BM7000 sources.
Is this correct or do I need to change the option settings on the Overture?
Regards Paul
I feel the pain of NL/ML convertors, I have 3. TBH the best thing I ever did was throw it at chatgpt and ask it how to configure the NL/Convertors. I said what was in each room, what I wanted to listen too and after a few queries it told me exactly how to configure them to work properly.
I went back to the manual, and took my own advice about Option setting. Setting the Overture to audio option 6 removed the need for the AV command. Still no ability to play BM7000 sources from the Overture. Paul
