Activating a non B&O Power Amp via 5V Trigger Powerlink Signal
I want to use a non B&O Power Amp with my Playmaker. I tried to use a 5v to 12v DV converter to trigger the mains relay I have but this didn't work. I've looked everywhere but can find a Powerlink trigger for using non B&O power amplifier with powerlink. My aim is to use a Quad or Valve power amp with the Playmaker instead of a Beolink Passive. Is all i need is for the trigger to switch the amp on.
This is a bit pricey but I like the look of it: Keene AC Powerswitch Relay Or Trigger Control for Iot Arduino Raspberry Pi ESP32 KPS1 https://www.amazon.co.uk/dp/B0765WBGK6/ref=cm_sw_r_cp_api_i_WBMC7Z5CASDSQ1Q8Z6VG?_encoding=UTF8&psc=1
Hi Guy - thanks, that is absolutely perfect for what I need - excellent, I've been looking for something like that for ages. Thanks again
Why not ask Steve? https://soundsheavenly.com/ Kind regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
