5v trigger from ???
hi, i have a canton pre-amp,  beolab 4000 and 2, and 7.4 conntected to a philips 65oled854. The philips tv has a 3,5 headphone jackets but there is no 5v on it :( its has an usb with 5v so the trigger works. But the speakers are on 24/7... now im looking how to get a trigger to get the sytem power on/off Now i have found out that the hdmi pin 18 has 5v on it. Has someone tried this out?  does this work out? is there an other better sullution to get a trigger signal?
Hi roycke, Welcome to Beoworld! I suggest using a separate mains-derived trigger instead of the USB or HDMI signals, this way you have easy control of the trigger signal and there are no annoying pops and clicks through the audio when the trigger voltage changes (as it often does when using USB):- https://soundsheavenly.com/line-in-connection/102-438-minijack-to-beolab-2-7-10-28-and-2500-powered-trigger-kit.html#/2-length-1m Kind regards, Steve.
@roycke I picked up some new B&O speakers at the weekend including a Beolab 7.2 for which the dealer made me up a cable to take the 5v USB trigger from the TV and the RCA pre-out from my AVR to the powerlink socket. I remembered this thread and asked him about the issue of the TV’s USB being ‘always on’ and he said that if a TV has a USB that’s always on then it must have another one that isn’t… not sure if that’s true but could be worth checking? Also if the TV does only have one USB, could there be a some kind of power setting which affects whether the USB is always powered or not?
