Breaking Beomaster 8000 for Parts
hi All,
breaking a Beomaster 8000 for parts.
if you need something send me a PM.
ALF
Hi Alf. ☺️
PM sent.
Jacques
Hi Alf.
I would like to buy this steel clips.
Login to view image Login to view image
Henrik.
y'know the springs you get in picture frames to push the backing against the glass? Those work well as an alternative.
A replacement spring could also be made from spring steel sheet stock. It is a simple shape that could be cut out with a Dremel or nibbler tool. The stock springs are 0.5mm thick.
Glitch
The following parts are gone:
uP board, display board, big alu cover - anything else is available ?
ALF
Hello!
The aluminium upper board hinge is available?
I mean the long black plastic piece that attaches the alu cover to the chassis.
Regards
i am not quite sure what exactly you mean - please go to the service manual, check the explosion drawing and tell me the part number.
ALF
Hi Alf,
I'm looking for the wood veneer in rosewood,
The left spring (under the release rail),
and the lid damper mechanism,
I sent you a pm :)
I would love to get the glass section from your 8000.
Do you still have it?
/Di ck
