wanted Beocenter2 cable box
Hello all, I recently purchased a beocenter2 not realising it didnt come with a cable box. Does anyone have one for sale? Im currently in France, but im interested in purchasing one from any country.
Have you just bought the head unit ?
If you have there are a few versions of the control unit so you will need to identify which one is suitable first.
Oh ok.
I have a Type No 2801 Item No 1280014 with SW 1.3 Headunit. So I guess one of the early ones?
Also. make sure it's not stolen...
I hope its not!, i bought it from a popular dutch auction house.
I suggest you ask B&O. If you give them the serialnumber, they can look it up in their register of stolen goods.
Sadly - quite common to see cables cut in a hurry, not realizing that there is more to it than just the head unit.
It's a mk1 version, the one without the "click" noise when you touch the keyboard,
These are not locked with a pincode, that depends only when on the socket.
Hi Beobuddy
If you are interested, I do have a Beocenter 2 ( incl. cable box ) working perfectly - for sale. I can offer you different sizes of PL cables, BEO 4 remote with the "GO" knob, extra cabel for head unit and cable box and wall mount for the cable box. The Beocenter 2 has DAB module and you will have a small active indoor DAB-antenna included....... :o)  You can have it all for DKK 2995,00
Interested....
Send me a PM
Kind regards from DK
Lasse
Hi beobudy, without the cable box and any cables is it possible to hear the click? (ie. is it mechanical? or electrical?) As Ive just tried and i cant hear the click)
Also have you recieved my emails about my beolab 1?
Regards Damian
I think you have null option to check head unit operations without black socket box and connecting cale.
