I have 4 RL35's and yes, they are embossed.
No embossed printing? Then it's like RL35's with sweaters...
You could get one of these made, the pic is for a RL 140, bigger than the RL 35s, a lot of holes, but you only need 2 holes to fit to the wall, and with the adjustment screw you can adjust the incline
First off: Apologies for the poor lighting!
Interesting, but mine have only 3 holes on the back, and there is not enough inset inside the hole (hard to describe), or lip inside the hole, to use efficiently (or safely) to hang the speaker....I'd be interested on the method to attach these...
My set up looks striking similar to the auctioneer right now (just moved the office into this room, and have yet to hang the BM 3300 on the wall..
And for the curious: the embossing
Take a look
B&O did make a wall bracket for these, ive only ever had 2 sets , but the bracket fits in all 3 holes and when tightened the offset screws lock it in tight, completely over engineered , which i loved about them, i dont have them anymore so sorry i cant post a picture
