Beogram 3000 Thorens TD 124 II
Crazy bidding on a rare item:
http://www.ebay.de/itm/Thorens-TD-124-MK-II-Bang-Olufsen-Beogram-3000-Typ-5210-/161570141511?pt=Plattenspieler&hash=item259e54b547
a collector's item, indeed....
Ralf
PS: not mine, I would not sell it!
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
  ..... and its a while to go yet.
I wouldn't say 'it's crazy bidding', not just yet.  An initial flurry of activity to set a base-line.
The interesting thing to see iwill be what it actually sells for.  Yes, these are scarce and sought after so I expect it to go a lot higher yet.  The question is, will is sell for more or less than what I paid for a fully refurbished (by Classic Audio) one last year.  If it does sell for higher then the buyer needs his head examining.  If it sells for less, then the buyer maybe has a bargain - relatively.
Unless you've seen or heard one of these (retored one), you don't know what you're missing.
Dave.
Very rare and the best Beogram. The Thorens TD124 Mk II is held up as one of the best turntables made and commands a high price. The Beogram version is rarer and attracts both Thorens and B&O collectors.
I assume that's yours Peter with the 12" arm?  I almost went for the longer arm from Frede but didn't in the end.  How much difference do you think it makes?
Dave.
Very little and it limits the cartridge choice as it uses an SP2. Looks very cool though! 😁 The reduced tracking angle error is certainly beyond my hearing powers!
The lid is interesting - this one is one I had made but Frede sent me a new one which is sturdier - I had sent him one of my design - the first broke and i had to send another! He obviously found a better manufacturer and kindly gave me one. These are great decks though and Frede restores them beautifully - what colour is yours?
Mine is a black TT and light Oak wood.
Dave.
Very pretty! Is the other turntable a Michell? How does it compare?
Hi Peter,
no, it's a Transcriptors Saturn - very similar and uses some of the same parts.  I have never used it!  The vestigial arm needs setting up properly, is very difficult to do and it takes days to do so I've never got around to it.  I only put it there as homage to the film 'A Clockwork Orange' - though they did use a Michell TT.  They look the same though.
Dave.
1230 euro   👍
