quality music streaming apple or samsung?
Hello, Im not a tech specialist so I drop a question here. I have a Beosound Essence II and I stream music with an Apple device. I was searching for quility differences between the IOS and Android platforms and all those specs about codec. With platform has a better quility?
  The quality difference between Apple and Samsung streaming platforms mainly depends on the codec support and hardware. Apple often supports higher-quality codecs like ALAC, while Samsung devices may rely on AAC.
If you care about quality you should never use bluetooth for audio to start.  Use Airplay and Apple Music or physical source.  Also Samsung and "quality" are rarely used in the same sentence ;)
