Beo Lab 2
1. Is there a way to connect a BL2 to an Oppo 203 (RCA), or 5.1 or 7.1 equipment that is not from the Danish brand.
2. The BL 11 is possible, via direct Line with an RCA cable to Power Link to equipment that is not B&O.
3. The same Power Link cable used by a BL2 can be used with a BL 11.
4. In two rooms 5x5; With a BL11 you would place another pair of BL3 fronts and on the other with BL2 a pair of BL 4. (both BL3 and BL4 use the Power Link 2)
5. A Cube 2 Focal SW sounds good to you, in a 5.1 accompanied by 4BL front and rear; or you would put 2BL 3 ahead.
