Albumcover in Beomaster?
Hi, does anyone have a solution to add and display covers in maps on the Beomaster5? I could not find earlier topics on this. Greetz, Jos
Hi Joris, see maybe this thread:
https://archivedforum2.beoworld.org/forums/t/46773.aspx I am sure there are more threads that you can find by hard googling :-). Using a tag editor can help you out. Album cover images should not be too large. Let us know your progress! Regards, Johan
Niet te groot =   max. 1000*1000 pix
Thanks everyone, I will try this out and let you know the progress! Regards, Joris
I am using EZ Meta Tag Editor now. It is very easy to add covers in the Metadata. Just double click on a music map, it is imported in this app. Then you click on " search for cd meta-data. Automatically searching in GD3, WMP, MusicBrainz  and Discogs. The album art will be embedded in all the music files in the map. Works brilliantly. Thanks for the workaround, Regards, Joris
