Beocenter 9300 MUTE function not working
Hello dear community, I'm in the process of restoring a Beocenter 9300 and I'm almost done. Now I've noticed that the "MUTE" function doesn't work. When I press the "MUTE" function on my Beolink 1000 or directly on the BC, I hear a click (a relay picks up, I would say) in the system, but the volume does not go to "MUTE". The volume buttons otherwise work perfectly. Does anyone have an idea what it could be? Greetings! Stefan
Hello Stefan, If you plug headphones in do the speakers mute? Julian
Beofan for many years with a penchant for 1990s audio systems.
Hi Julian, thanks for your E-Mail. No I plugged in my B&O Form 2 Headphones ;-) and the speakers dont mute ifΒ  i push the Mute-button but the red Mute-Light switchs on like normal. But the sound in the earphones and loudspeakers is still on. Stefan
If you are using passive speakers; are they connected to the Speaker 1 outputs? If they are in Speaker 2 they won't mute (by design).
"Bang & Olufsen - A Life Less Ordinary" // "It's not magic, it's the Bang & Olufsen link system" // "It takes more upon itself, asks less of you. And a natural consequence of this is the simple and striking design. The true harmony of form and function spells beauty in any language"
Excellent point @lausvi πŸ‘
That's because speaker set 1 is meant for local use - in the same room as the Beocenter. Speaker set 2 is typically routed to linked systems in other rooms, where they are muted locally - and independantly. Martin
Lausvi, Martin-Dillen, Julian-Pepps, Iam really sooooooooo stupid. After all the soldering work and some heart attacks I used the wrong Speaker outputs. Sorry! Now its working as it should ;-) Have a gerat evening! Stefan
Excellent! Enjoy your Beocenter 😍😍😍😍🍾πŸ₯³
