Heribert wrote:
My question was very general about the AST. I learned so far that it just works with a Beosystem 3 powered setup (sad for me who owns a BV8). I also learned that I can make different sound preferences according where I am and what source I listen to. And I need 4 speakers (without center). Correct so far?
Almost. You can create a numebr of different "Presets." When you create a preset you define the following:
- AST On or Off
- Which loudspeakers are playing
- The location of your listening position
- The direction you are facing (called "rotation" in the Preset)
- The name of the Preset
AST can be turned on with as few as three loudspeakers, however, I would personally recommend that you use at least 4. Of course, the more loudspeakers you have, the better the spatial resolution of the system. You can have up to 7 "main" loudspeakers + 2 subwoofers running in an AST Preset. Those 9 loudspeakers can be chosen from the 14 outputs of the BeoSystem3.
Heribert wrote:
Next question is: who does the system detect where I am? Do I have to change manually the position (like I can do with Speaker 2 or Speaker 3) or is it done depending on where the IR Signal comes from?
When you create a preset, the system will "ask" you to put in the distances from the listening position you've chosen to 3 of the loudspeakers. From these three measurements, it triangulates your listening position and "knows" where you are. Then, when you change Presets (manually, using the Beo5) you are changing the listening position to that which you have set.
Heribert wrote:
My problem with the current setup is that I use Speaker 2 for Audio and Speaker 3 for Video. The sound setting is based on the video needs. BL3 (Right) is around 3,5m from listening position - and BL3(left) around 6,5m). BV8 is also 3.5m away. Works well. But when listening Audio on Speaker 2 I have another position quite in the middle to more oriented against BL3 (left). Would AST help here? I guess that is what is was made for?
If I read this correctly, you have 3 front loudspeakers and no surrounds. In this case, I would say that AST will probably not help you. If you have surround loudspeakers, then AST might give you an improvement. Your loudspeaker configuration seems quite asymmetrical - and this is the kind of setup where AST helps most. However, you will need to be surrounded by loudspeakers for it to really work effectively.
I hope that this helps. If you need further info, please feel free to ask!
cheers
-geoff
