Search issue in forum 2012-2022
If I try to search for a topic, could be "Beogram CD 50" in the older forum 2012-2022 I get nothing. I tells me this "Sorry, we were unable to find any results using your search terms. Please change your search terms and try again."
Everything I try with gives the same message.
Are there are problem with the forum?
/Pindsen
Not sure.  But as a temporary workaround, try using google and after the search term enter site:https://archivedforum2.beoworld.org/forums/"  without the quotation marks. eg: beogram 6000 site:https://archivedforum2.beoworld.org/forums/
Okay, the Google string works, it provides the search results in separate links - but it's useable.
I just tried if the search function works Today, but still get the same message:
/Pindsen
Hi, I also get no response from any
Thanks for highlighting.  I have just reported the problem to Multicare.
@MJBeo - ArchivedForum2 should now be working, but its 'search' function is still work in progress.  The google search (using site: etc) should be a useable workaround in the meantime.
Great, thanks!
