Dear all,
I am looking for help connecting Beolab 5 MK1 to Beosound Core. For a while, I was using 100% PowerLink. Sound was great, but there is a small white noise. It was similar with a Beoconnect Core. Couple of forums mentioned it. Cables are 5 mm official B&0.
I would like to use digital connection to get rid of it. I plugged, on top of the Powerlinks, 75 ohm coax cable, plugged to Toslink out. Conversion is made with Lindy 70457.
Control works well, speakers turns on and off, volume toggles is moving on the source, on the apps, and B&O remotes can control those visual, BUT there is not sounds at all. Even the white noise is gone. When plugging one speaker, I could get a low volume sound, but when plugging all to move the speakers, sounds it gone again. This archive topics is related, but not solved https://archivedforum2.beoworld.org/forums/t/47094.aspx
I played with cables, apps setting (48 kHz signal, with and without volume control), L_OPT, V_OPT, A-OPT, Airplay, cables analog source on Line in, and still nothing. I suspect my converter does not fit the needs but I do not know why.
Would you have any ideas?
Thank you,
Benoit
