How to change your Avatar...
As we've said repeatedly, we're adding features as we go - and we've now added the feature to change your Avatar before you post.  For those who have already posted, this can serve as a short cut if you will. At the top of your page you should see a black bar with "Welcome to Beoworld Member ****" If you hover over that there should then be an automatic drop down.  The section we've added is "Edit Profile" If you click on that you'll then see an option to upload your image. Once you've done that, simply update your settings by clicking the relevant button of the same name, and your new Avatar will display immediately! Kindest Regards Lee
To clarify go to the top right hand corner and you will see the following
I’ve tried a few times to do this but failed…..I now get a message saying I’ve committed a potentially unsafe operation and I’m blocked……can you help Keith?
Can you please try again.. Keith
Still getting the same message.
Exeter, Devon, UK
I have logged out, cleared my cookies and logged back in but still getting the message. Is there a max size for avatars? I have just noticed the time on that notice is an hour out.
Exeter, Devon, UK
I have added to this test account Keith..
Looks great Keith. Thanks.
Exeter, Devon, UK
