if you login at the bottom of a topic, it should only reload the page now and not go to your account page. :-)
Repairs and refurbishment to both old and new.
sure :-)
This is a link from email inbox:
https://forum.beoworld.org/forums/topic/keyboard-beosound3-new/page/2/#post-126129
Hopefully this is resolved, the issue was that the link you mentioned was for the old forum. the new forum has a slightly different url structure.
I had put redirect in place but it seems to have skipped this one :-( anyway, hopefully it should now redirect correctly
Things are improving greatly!
I'm researching this newly discovered thread to help me with my own upgrade path for a 5500 retrofit:
https://forum.beoworld.org/forum/imported-unmapped/beomaster-6500-slight-overhaul
Some of the archived pictures are working again, and it really helps with dissecting the content. But there are still several pictures which were archived and are not appearing (yet they may appear in other responses, so I would imagine that they are in the database). Perhaps there are still a few references which are not quite working?
To add, there is a link or two to other threads in the same discussion which may not have been remapped correctly.
Also also, some of the pictures do not allow for a "Click-to-enlarge" - the underlying URL is simply mapped to the home page, so when you clcik to view the picture, you get redirected to the home page instead of an enlarged image.
Looking good! Thank you again for putting time into this.
Perhaps I'm missing something or not on the right page, but I found the old "latest activity" links helpful when they clicked through to the last post of the thread. Current behaviour is taking you to first message of the thread?
This should be sorted
this will take some time to figure out unfortunately. I will keep looking into it.
Fixed
Most should be working now, I think a lot of the references were old emojis.
Very nice new look and feel of the new forum!
Great progress.
On page 1 of the 6500 thread, the pictures can be enlarged per expectations when I click on them. When I move to the next page, the image enlargement doesn't work, but I can still enlarge the picture by right clicking the image, and selecting "open in new tab".
BTW no need to fix this if you are having to manually edit all the individual posts to make it work. I'm only pointing this out in case there was a programmatic error that fixes the issue for multiple threads when it is corrected. As far as this specific thread is concerned, I'm quite content to "right click" and open the image on another tab.
Hi, I still seem to be timed out on my login. It doesn't seem to matter if the site is open or closed and I have ticked the remember me button.
Regards Paul
