Beocenter 2300
CD does not spin. Laser replaced with no result. Any good ideas?
Does it start to spin and then stop - is there any rotation? It could well be a problem with capacitors. Have a look at the following threads, according to the type of CD module fitted: (Older type, with curved laser path)
No nothing happens exet for a sligt hum when I push cd button. Have also replaced all capacitors at the pcb.
Do you have a remote, and if so does it work when you use a remote?  Does the FM radio work?
Yes the FM radio works, but the cd is not spinning. Have now replaced the whole cd unit with the pcb on it, and still not spinning.
What type of BC2300 do you have?  Straight or curved path laser?  And what CD module is fitted?  Perhaps add some photos. I would be checking power to the CD module, and the security of any ribbon connectors.
Heee is a pic of the type:
Thanks - the picture is useful. Have you checked everything that is mentioned in the second of the two threads I posted earlier?  This one:
I Think IHawe a Power issue, so Will try to look for that First, but thanks for reply. if any good ideas please let me know!
