Sustituto del LC2
The RAone SmartDimmer is perfect for creating a specific mood anywhere in your home. This Danish designed and developed light dimmer is operated by a light touch of the finger-touch panel. With the INNOVUS SmoothRemote, a B&O remote or a Logitech Harmony 890PRO or Harmony895, you can operate the light dimmer from your sofa or from bed.
The RAone SmartDimmer is more than a light dimmer. It is your entrance ticket to a world of opportunities for smart-controlling your home. The RAone SmartDimmer was created as a part of the INNOVUS Home Automation system, by which lighting, heating and security are controlled via central switches or a remote control device, providing convenience, security and energy savings.
The RAone SmartDimmer in the children's room
The RAone SmartDimmer helps your children fall asleep. Two light touches of the light dimmer and the light will fade slowly over a half hour while the children fall asleep.
The RAone SmartDimmer as energy meter
The RAone SmartDimmer has a built-in electricity meter that measures the electricity consumption of the lamp to which it is attached. Together with INNOVUS House Control, it provides a valuable overview of the energy consumption in your home. (The electricity measuring function requires INNOVUS House Control.)
http://shop.innovus.dk/group.asp?group=8
¿Habéis leído este post en el foro general?
He pedido 3 de éstos esta mañana, a ver si funcionan tan bien como dicen.
Ya os contaré, por si a alguien le interesa.
Pues a mi me interesa, estaba siguiendo este hilo en el foro general. Esperaré impaciente tus comentarios 😁
Me interesa saber si se puede programar y configurar. Si se puede seleccionar como luz nº2 por ejemplo, o si se puede hacer una configuración con varios interruptores como se hace con el LC2.
Si hace exactamente la misma función que el LC2, compraré una buena cantidad. 🙂
Según el manual, se programan exactamente igual que los LC2.
Sabéis si funciona con lámparas de bajo consumo?
Parece ser que una nueva versión que saldrá en abril sí funcionarà con estas lámparas, pero mi inglès no es muy bueno. A ver si esto ayuda:
Notice that the next version of the RAone lightdimmer that  comes in this month (marts/april)  will could be used  with the new ligtning tecnology called LED or OLED.
LED lamps will only be possible to dimmer with new generation of lightdimmers.
 A LED lamp  that gives the same light as a normal 40 Watt bulb, are  only using 5-7 watt and normal (old) lightdimmers will not could  be used, becouse the ampere (A) is to low
 http://www.rgb-lamps.dk/FarveL12.htm
Today its only possible to get 40 Watt LED with a life time of 50.000 hours . Proberly next year it will be possible to get a 60 Watt LED with same lifetime, and then it vill be  time for change bulbs in the hole house.
Cierto Joaquín, acabo de ver el manual que has enlazado!
Está muy bien. Esperaré a ver que tal te va y compraré unos cuantos.
Gracias.
La verdad es que tiene muy buena pinta. En el foro general hay gente que lo ha comprado, y hablan bien de él.
Rafa, tendremos que pillar unos cuantos.
Yo necesito como minimo 3. Y con el Beo5 se pueden hacer cosas muy chulas.
Estaba pensado en hacer algo así como una macro para que la luz bajase de intensidad poco a poco,... y esas pijadas.... 😁
Pues sí, con el Beo5 y varios de éstos se pueden hacer bastantes cosas..... quizás hasta olvidarte de Lutron.
