- Clued back the loose coils
- Put in the same Cross Caps as for the first pair
- Changed all the wires to Silver Plated OFC Copper PTFE Sheath 1.5mm²
- Changed all the resistors to Mundorf MR10 non-inductive metal film 10W
S45-2 project x 2
So it started with getting a Beomaster 1900. Never owned B&O product before, just liked the look of it :) Anyhow, then quite randomly came across a good looking pair of s45-2, picked them up the next day. No scratch on it, beautiful. Sounded kinda ok, tiny bit muffled I'd say.
Wires
Original wires it came with one of them was cut/fixed. That one sounded notably quieter. So I changed it to a new wire (2mm²). Now that one sounded better and louder, notable difference again. Made new wires, with aftermarket connectors that felt flimsy to say the best.
Recapping
Opened it up everything looked in order. Changed electrolytic caps to new Jantzen Cross Caps. Opened up the sound quite a bit. Cross Caps are a fair bit larger but wasn't too hard to fit them in there.
Changing the terminals
As I wasn't happy with the connectors and using thicker wires I ended up changing to SpeakOn terminals. Old terminals come off just by pushing them inwards. Added a little epoxy to the inside groove as the MDF around there was little crumbly. Added epoxy to the back of the SpeakOn terminals as two pole sockets have two empty blade holes. Made it nicely air tight. SpeakOn fits in there just perfectly with no cab modifications needed. Some hot glue on the inside and done.
Project 2
Now somehow I ended up picking up another amp, 1900-2. Faulty, with hum, missing one channel etc. But sounds good after full recap. So I needed one more set of speakers. Ended up winning an auction in Ebay for a good price. Another pristine looking pair, perfect, not a scratch on it. But the day comes it arrives to my door, oh my!
Fellow had packed two speakers loosely into a thin cardboard box with no padding at all. Aluminium corners had rubbed the cloth all broken on both, back corners dented of banging around. Coils broken loose inside. That wasn't a good day. Fairly enough seller refunded it fully and let me keep the speakers.
So I thought why not mess around with them a bit more, try few things.
Rebuilding the inside
As some of the wires and resistors inside looked burned and melted I thought I change it all.
Hi Tanel!
I want to replace cross over capacitors with the same Jantzen cross caps you chose. When I look at the circuit board (made out of wood!), it looks a bit complicated. The three caps I want to replace are sort of intertwined with other stuff. I had hope, I could simply desolder the old ones and solder on the new ones. Or is it ok easy to replace for a beginner "solderer"? (I can build bicycle wheels and fix pavoni espresso machines, so I thought I could handle this too!).
Would you happen to have a a photo of the back site of the circuit board - before and after, so I can see how yours look?
And if you could mention other "need and nice to know" about replacing old cabs with the Jantzen caps.
My stereo: Rega planar 3 with Excact cartridge. Musical Fidelity A1 amplifier, Beovox S45-2 speakers
Hey! Oh, looks like I wasn't subscribed to the topic and missed the question.
I don't have a picture of the back side of the board, but there is no much of a back side to it, just the edge. I'll add before picture, there one can see what connects with what.
And another picture with the cloth restored, Christmas style :)
Didn't use clue, just double sided tape on the back of the edges. Very stretchy fabric, so quite forgiving to apply.
And one more experience from working with these boxes. For a long time noticed that both my S45-2 pairs sounded like having a gain threshold on bass, it was punching through on low frequencies but somehow lacked the character and smoothness in low end. All the bass kinda sounded the same from double bass to synths and sounded uneasy. Decided to look into the box again, and realised I had stuffed the back of the woofer too tight. Now properly lined the filling to the walls only, and thinner on the back wall. It brought back the good flow of the bass. Can say there may be a just a tiny bit less of that very low frequencies now but certainly sounds better all together.
