Replacement woofer S45/S55
Has anyone experience of these:  https://www.bluearan.co.uk/index.php?id=BMA8BR40N&cw=438&cn=Woofer_for_Beovox_S45_8%22_Bass_driver&srsltid=AfmBOop36MVfN3yF-UkLhIz4xy-CQINonGbeyDxKf3FYK8sywAJyf2Oy If they fit S45 they should fit S55 as physically they are the same width (21cms) I have a pair of S55 in nice condition. Woofers needs re foaming. Would one of you experts suggest I just replace with these or stay with the generic ones??
Stay with the original and have them refoamed. They are unique for these models. 6,4 Ohms if I remember correctly. Size is not everything when it comes to speaker drivers. Look at the list of T/S parameters. Martin
Thanks Martin Yes 6.4 ohm. I am going to follow your valuable advice Michael
Martin Ive read the importance of gluing the magnets; do you apply a bead of glue at the top of the magnet where it slips inside the holding basket??
