BeoVox Penta Center Channel Concept
I got a BeoLab 7.1 (wired using both left and right channel as center channel).
It is at great center speaker with lot of power and clarity.
If you go for at home-brew solution with a passive speaker I would build something around a non-B&O center speaker ... A good second hand B&W or whatever you prefer. I believe that will give you a way better acoustic result.
You can still modify the speaker cabinet to match the Pentas in some way.
A Penta is way to big... a simple Redline 40/60/120 will do the job.
The important thing is: the speaker must fit to human voice. Too much bass will destroy the effect... and a standard Penta will not work, you must first remove the bubble wrap foil in it's sound way.
Hey BeoWorlders, just thought I'd share another whacky idea that has been bouncing around in my head over the last few months.
I have two systems that utilize Pentas as L and R channels. One set up (bedroom) uses a BL4k as a center channel and the other (living room) is not equipped with a center at all so just running in stereo. The situation is that I use both for a ton of movie and TV watching and want to upgrade the center channels in both systems.
After a year of listening to a 3.0 system that had a woefully mismatched and underpowered center speaker, I've been on a mission to scheme up a solution to get away from this. Not only do I want a home theater system to match the power and spectral capability from all three front speakers (L/C/R) but I also want to match the Timbre as much as possible. Center channels are usually heavily compromised from my point of view and we all know that the center channel is where a majority of content comes from.
So what have I come up with? Well the concept is pretty simple, build an alternative enclosure so that the Penta transducers can be packaged more efficiently as a center channel speaker.
Why redesign the speaker package I hear you say? Why not lay a Penta on its side in front of the telly and call it done?? There are a few reasons. Primarily the need to stand up the center midrange array. Its important to place these midranges vertically so that the array physics appropriately cover the horizontal listening space for various seating areas etc. Secondarily is more of a practical reason - laying a huge Penta on its side in front of the TV is just not going to work from a space perspective.
A few minutes of slideware engineering and here we are:
Login to view image
Originally I thought I would 3D print it in sections and then assemble. However I suppose it could be made in wood and CNC'd as well. The advantage to 3D printing is that its very easy to do so once the CAD is finished and it could be potentially styled to match the shape of the Penta cabinet in some interesting, abstract way.
Basically all the transducers would be a carry over from a donor Penta along with the twee-mid module that could essentially just drop in. This arrangement should also keep from having to redesign the crossover but I'm sure the experts among us would say differently.
Let me know what you guys think.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
et me know what you guys think.From a general sound perspective, I don't see any reason why it wouldn't work. As long as you keep the cabinet volume and reflex tube length/diameter the same you will, in general, have a similar frequency response. Even if you mess up the very low frequency response, this won't be critical for voices since they don't contain those frequencies. Would you actually be happy with the form factor? I'm having a hard time imagining what this would look like under a TV. Did you plan to have the bottom-most mid-range close to the floor? Not having the tweeter and mids at ear level may mess with the vertical dispersion. I don't know if this is a better or worse trade-off versus having the mid-range array horizontal. Have you considered using a (well matched) pair of Pentas (in the original configuration) placed tight to sides of the TV? The mono pair would provide the a solid centered image and the apparent sweet spot could be roughly controlled by the angle. The other surround" speakers could also be Pentas for the full overkill effect. ;-) Glitch
Unfortunately you do not write anything about how you want to connect the ‘new speaker’ - do you use an A/V receiver or will it be connected to a Beovision…..in which case, what is the amplifier?
Apart from the physical drivers in the ‘new speaker’ there are multiple things that can influence the sound.
I would do as Ravsted….get a BL7.1 - alternatively/or even better a BL7.4, if you have room for it below the tv.
Thanks for the replies everyone! Nice to do some brainstorming among the like-minded. This is still a thought experiment for now (many other projects still in flight, as usual). I don't like to keep crazy ideas to myself just in case there is someone else out there who wants to join in on the fun and build this stuff along with me.
Just for context, I have a BL10. Yes, it should do the job and sometimes did deliver the power it contained (mostly in gaming situations) but the overall sound character (timbre) was very very mismatched. Basically ended up not using it most of the time. Vocals are always the focus of the center channel but there is often times far more content coming through than just voice. Also this isn't the only experience driving this project, many systems I have heard are usually weakest in the center channel for various reasons, but usually packaging related.
