The "Beovox 3" service manual in the Beoworld library only covers the MS150 Type 6411 and it appears the crossovers are very different!
Beovox MS150.2 crossover schematic
Does anyone happen to have a copy of the service manual, or even just the crossover schematic for the Beovox MS150.2 loudspeakers, Type 6431, please?
Just an update - I found pictures of the MS150.2 crossover online and it appears that mine have been half re-capped! However, one of the original capacitors has broken and one of the replaced caps appears to be the wrong value.
Consequently, I have done what any sensible person would do in this situation and ordered a full capacitor kit from Beoparts!
Would still be keen to know if there's a service manual out there, though.
Hi Adam,
Service manual for MS150 type 6411 and MS150.2 type 6341 attached.
Best regards,
Jens
Best regards,
Jens
Jens Rendboell
Thankyou Jens; that's very kind!
Hello Jens and Adam, could one of you please repost the MS150.2 service manual? - it seems to have gone missing from the previous post.
many thanks!
many thanks!
Also just the crossover schematic would be great if anyone has it...
Cheers, Jonas.
Cheers, Jonas.
Hello Jens.
Is it possible you could send me the service manual and schematics for the MS150.2 as well. Thanks in advance
Best regards
Jesper
Best regards
Jesper
