Weird format issue with beovision avant 28 mkI type 8111
HI and welcome to Beoworld! There is some sort of phenomenon known as 'RGB shift' that has been discussed previously on this Forum - it sounds like what you are experiencing. It was discussed a little here:  From memory I think it can be corrected in the service menu ( I vaguely remember trying), but will probably cause issues with other format (non-RGB) inputs, if you use them.
I think that this is the thread that I remembered (about an older Beovision) with advice about changing the HPHASE setting for an RGB input:
Hello everyone! I'm having a weird issue with this tv (got it for free really randomly, never had a b&o crt before, love the quality but it's a pain to setup). So, I'm having difficulties understanding the formats. The 5th and the 6th formats are for 4:3 and 16:9. I'm pretty sure that the previous owner touched stuff, because the geometries are a bit weird, nothing that cannot be fixed within the service menu, but apart from that there is a big issue: some of the left side is not showing in 4:3 while in 16:9 you have a complete picture. (I'm attaching some images to show the issue, on the 4:3 one you can see that "kenshiro" is a but cut, on the 16:9 is all complete) After this huge premise, does anyone know any possible fix? I'm using now a ps2 in rgb with hokuto no Ken, but I've tried the same thing with the Wii and the 240p suite and I have the same issue (Yes, I want to mainly use it for retrogaming) Thank you all ❤️
Thank you so much for answering! Unfortunately the Hphase only moves the image position horizontally on the screen, not the image itself (I thought aswell that it was a RGB Centering matter). I've just noticed that in the service manual there is another parameter that I need to move in order to center the image, but I couldn't find it (I've opened it up searching for knobs inside but I couldn't find anything). Do you/anyone have any clue on how to do this? (the matter is explained in the image attached :) )
