Would be helpfull if you could post a picture of the connection panel there.
Why the instruction above recommends connecting the analog (L/R) as well as the digital coax, I don’t knowI think that's in case your TV is connected to further TVs in link rooms. Only the analogue signals would be distributed, whereas digital available in the main room for better quality/surround.
Looks like two sets of identical cables.It is one cable, but in one end the individual cables just have some length to fit the space between connected components. wired up for 2 whole sets of connections with both analog sound Left and Right (phono plugs with thin wires), digital sound, coax (phono plug with thick wire), composite video (phono plug with thick wire), S-video (S-Video plug), and data/control signal cable (2 pin minijack). My father got me two sets of these cables once when he was still working at B&O. I striped them down and rebuilt them to make cables for sound from PC to stereo, and video cable from computers to TV's. Hell of a work to get those cables disassembled as the wires inside are twisted.
Next question, Any idea what the DATA cable and Digital output cables might look like? I’ve been searching around online to find somewhere to order those without avail.The digital cables are with phono plugs as described above. The data cable is the one with 2 pin minijack. Looking at the picture though it sees like it is with a male connector in one end, but with at female connector in the other end. I think you will need a 2 pin minijack cable with male connectors in both ends to be able to connect it to the DVD players data connection.
