Finally got back to this having been diverted by 4m3 of logs for my fire, they needed splitting, stacking etc
Back to the tilt arrangement.
I found a piece of silver steel, 3mm in diametet, cut a 3mm thread on one end to mount the turnbuckle.
I then cut the piec to approximate length, and cut a 3mm thread on the blank end.
I cut a piece of 2mm ali strip to create a mount for the rod, I intnded using an STB tube mount.
The strip had a 3mm hole on the projecting end.
Login to view image
The central cable mounting area in the bottom centre of the rear of the tv was drilled out with a 4mm hole.
The left handed threaded piece was mounted there using a 4mm screw. The right handed thread piece was then fitted and the length needed was measured.
Login to view image
The long piece was then adjusted, the pieces were then mounted and the cable tie was removed.
Login to view image
Login to view image
Login to view image
Login to view image
Login to view image
With this system and all the thread piece screwed in the screen is virtually vertical with the possibility of and adjustment of around 30mm to give some tilt of said screen, time will tell if it is sufficient,
The various scratches etc will be burnished away when I locate my Micro Mesh kit!
This has been an interesting challenge, I think it is going to be successful!!
