Region Code for integrated DVD in Beovision7-40.
Hoping someone can help set me straight on the in-built DVD in the Beovision7- 40. The unit has defaulted somehow to play only Region 2 discs, not Region 4 which is Australia's region code. Is there anything I can do to change it back to Region 4, or multi-zone it, or will it have to go to a service centre ? regards Noel
Hi Noel, I had a quick look at the service manuals (available
Whilst the region setting can be change with the service tool, its not a requirement. Eleven years ago I wrote the attached document and made an XML file for the Beo5/6. Attached is the Procedure for setting a Beovision 7 & AVANT DVD to Region Free
Thanks for all the help guys. Thanks Keith for the procedure sheet- but how do I disconnect the DVB-T module ? regards Noel.
And the sheet refers to a "special" Beo4 Remote ?
Hi Keith, Many thanks for your reply, and supplying the procedure sheet. I will have to try and get access to the special remote. regards Noel.
