Hi
I have beatiful B&O crt - MX7000.
https://www.beoworld.org/prod_details.asp?pid=642
It is the best crt that I have ever used, perfect for retrogaming especially. I have one problem though - visionclear technology.
https://www.beoworld.org/article_view.asp?id=73
Part of this VisionClear technology is brightness sensor in upper right corner of the tv.
Is there is a way to disable the VisionClear light sensor? It dims the screen way too much especially during evening and only brightens it in direct sunlight. When shining a light into the sensor the brightness and contrast get a lot better.
Is there a way to skip this brightness sensor to have maximum brightness all the time? I didn't found any such option in regular menu nor service menu?
