Mounting a Beovision 10 to a motorised stand
Hello. New user here (though I've owned a Beovision 7-40 for 12 years) and I'm struggling to find a difinitive answer to my question. I have an opportunity to buy a Beovision 10 which is presently mounted to a wall and unfortunately I can't do that but I do have a motorised stand.  The Beo10 is about 100 miles from me and I'm not really getting much info from the seller (friend of a friend so quite happy to trust them) before I go to buy it; inc they can't supply me with model numbers etc. My question really is, will all variations of the Beo 10 mount to an older motorised stand and more importantly is there one bracket and one fitting point for all Beo 10 TVs?  I've Googled it and the info seems varied and never seems to show the same plate/bracket and even when I find what looks like the same fitting for my stand, I can't see how any bolts would line up as there appear to be no corresponding holes on the Beo TV I'm interested in.  I'd hate to buy the TV, get it home and find that it is a pain (or worse) to get it easily mounted to the stand!  To buy a genuine bracket also looks prohibitively expensive! Many thanks. The only pic of the back of the TV I could get + my stand (I will be removing the centre speaker).
Hi and welcome to Beoworld! Your photo shows a BV10-40 or 10-46, I am not sure which.  Either way, even if you had the correct 'spider' piece (labelled 9517 in the diagram) which fits onto the back of the BV10 ready for stand-mounting, the black holder piece at the top of your current stand is too wide to fit into the slot.  On the proper stand (see below) the part labelled 9515 is narrower. Diagram is from the service manual (full manual available on site to Silver/Gold Members): (click to enlarge) I would look for a second-hand BV10 stand - they do come up on the usual sites very occasionally!
That's exactly what I hoped someone could help with, thanks Guy.  My head was battered looking at flat plates, ALIEN spiders and a couple of other options and there was just no definitive, easily understood answer. It seems a shame to waste the present stand, I may see if I can source a 9515... though if a BV10 stand came up, I could sell the stand for the BV7. Thanks again.
