Limited HDMI bandwidth on Eclipse Sound Center 1st Gen ?
I have found this document in the old forum:
Best regards
Dyssegaard
Interesting.
Thanks for sharing. I was not aware of this. I recently got my hands on a 1stgen Eclipse.
Its says in the guide that you should use the HDMIs in the TV it self rather than the ones in the Soundcenter if you want to benefit from Dolby Vision. I will do some tests and report back, since I have the latest ATV available.
However, if you use the HDMIs in the TV it self I do not think you can use the PUC cable, hence you need to use the AppleTV remote.
Did a quick check with the latest AppleTV 4K connected to the Soundcenter (HDMI D) and had it configured as per the instructions (4K SDR, Match content On).
When I play a movie from Netflix that is Dolby Vision, the panel signal that it is indeed Dolby Vision being played.
I set ATV to Dolby Vision/60.
played a video on the YouTube app that was supposed to be DV 60.
This is what the stats liked like:
Login to view image
Does is makes sense?
Login to view image Does is makes sense? Thanks again for checking. And yes - it does make sense. I don’t think that it was displayed in DV or HDR. If you look at the Codecs line it should have been 9.2. I played a DV-video in the webos youtube app and the panel on the TV shifted to HDR-mode. Maybe it will work if you force the ATV to HDR/60. For youtube videos I will be using the webos app in the tv in the future since it can display HDR/60 videos. The problem is with apps like Disney+ and ATV+ since they are not available on Eclipse 1st gen. They are available on the normal LG C7. I have been in contact with B&O about the missing apps. They are aware, but suggest to buy an ATV and use the apps there .. Best Regards DyssegaardLocation: Copenhagen
Best regards Dyssegaard
I remember there was a modification made to the first generation Eclipse to address the limited bandwidth problem in the HDMI sockets. A new DSS board was manufactured and was available for replacement for the early sets.
The board replacement was done for free under warranty.
I got my own Eclipse in 2019 and the problem was fixed at the time.
Jean
