LG software update affecting TV control
My Eclipse had an LG software update last night and since then my Beoremote can only control the HDMI sources attached to the Soundcenter. I reported this to B&O and they have confirmed the software update caused it and they are working on a solution. Here is the link to the announcement which includes 2 work rounds https://support.bang-olufsen.com/hc/en-us/articles/20651659644561-Important-news I will let you know when I know more. Paul
Just had an update from LG and it now seems to be back working
Thanks,can you give me the buggy version number (23.25.55?), and the new version number ?
Hi, the buggy version was 23.25.50 the new version is 23.25.55. Hope that helps. Paul
Thanks,and what are the symptoms on your TV?Because on mine,after a bit more than an hour usually, I get a message « network lost » and then « network connection reestablished » again and again until the soundcenter crashes and I get only sound from lg speakers. But I think it may be related to a hardware fault on my side.
