CRT - Visual issue on MX8000 (with 576i?)
I have an issue with my B&O MX8000 which I am trying to use for old games.
When playing in 240p I seemingly do not experience this issue but when using either my Playstation 2 or 3 thru a RGB scart cable (happens with composite as well) I see this awful issue when panning. It almost looks like playing interlaced content on a regular monitor that doesn't deinterlace.
Which PS2 games did you try, I can compare on my MX8000, I see what you mean in the video, that's a really weird issue.
Cool, I have GTA: Vice City and 3, any particular spots, If you take another video of both etc I can try and replicated the same scene/see if I get the same issue.
Where are you based? I have an MX7000 and MX8000 and whilst I've barely used the 8000 yet, its low hour and the colours are stunning!
Looks like an interlacing problem. Can you change output resolution on the PS2 and PS3? Or the refresh rate?
I doubt you can change any useful setting on the MX8000
Refresh rate should be 25 or 50Hz.
Resolution 576i or 576p or PAL (I assume you are in europe?)
