Control of link/borrowed sources from Beovision 11
Hi, I have a BV11 in one room and a Beosound Core in the other. the BV 11 is setup to borrow Music, Radio from the Core. When I call "link-music" or "link-radio", it starts, but I cannot change channel or go to the next track. I can only play/pause. Also from the Bang&Olufsen app, I can't do these operations either, nor can I queue a new song or change radio station if I'm controlling the V1. I can control the Core, but then the speakers in the other room start too. I've just move from a Masterlink system to this Network link system and I do not yet know all the subtleties. Philippe
Why not just use the built-in Netradio of the BV11/V1? At least for radio listening that should be easier. MM
Thanks, that was an example, but I listen to Deezer more often than radio... And I wonder why I can't control borrowed sources properly, it's something that's been there since MCL!!!
Hello Phil,   Did you upgrade the core to the latest firmware? There’s a bug in this new firmware for all the NL devices that’s broken that functionality for controlling the lead source. In my case I can no longer change radio station or CD using the number pad in a link room. I reported this to B&O support and they replied saying they are aware of the issue. Rob.
I've now moved the Beovision 11 in the Bedroom (as originally intended) and plugged the speakers onto the TV, the Beosound Core is now setup as "integrated", and all works correctly now.
