Connecting Beosound 9000 via Beolink to Beovision Avant 85
Greetings, Please advise how to connect and setup this chain of devices. I connected the Beosound 9000 to the BeoLink Converter NL/ML with the MasterLink cable, but I am not sure which RJ45 ports need to be used to connect the Beolink to the Avant TV set (both sides). Second question is about the setup of TV set. What steps of the TV Menu to follow to set-up use of Beosound 9000 via Beolink? Many thanks
You should be able to find the answer to your questions (and more) here: https://cdn.webshopapp.com/shops/98396/files/334286248/beolink-converter-nlml-ver-14-beomac.pdf MM
Many thanks! Will give it a try!
the difficulty is how to integrate the BS9000 with the Avant and how to start the BS9000 with a remote and/or B&o app. Not all devices are compatibel. if the Avant is not an Android version, it is possible to connnect, if Armit has another NL-device in his Network the solution would be obvious, if an IR eye and speakers are connected to the Beolink converter NL/ML (BLC) it should be possible.
