Can not change channel using BROne and BV11
I have my Beosound 1 integrated with my Beovision 11.
If I press RADIO on my Beoremote One (IR version), I get Tunein playing on the BV11 from the BS1 Tunein source. So far all good.
I recall that I used to be able to change Tunein channel with the remote, but does not work now. No matter what button I press. Only volume works when playing Tunein.
Is that something that have changed?
/C
I just joined the BV11 to the Beoplay 6.
Playing (dlna) music I could skip to the next and previous track with a BR1 (ir).
Although I do not use TuneIn anymore, skipping between radio stations on B&o Radio worked with the BR1.
Note: the BP6 is not integrated with the BV11.
Hello Hiort, sounds like the same issue that Rolf2 and I have, see here: https://forum.beoworld.org/forums/topic/bo-radio-migration-available-now/page/4/#post-12269
We found that after changing station once in the app, then changing stations with the remote works as normal again.
Regards, Johan
Hello Hiort, sounds like the same issue that Rolf2 and I have, see here: https://forum.beoworld.org/forums/topic/bo-radio-migration-available-now/page/4/#post-12269. We found that after changing station once in the app, then changing stations with the remote works as normal again. Regards, Johan
Thanks Johan! That worked for me as well. The drawback is that the Beosound 1 the goes from mute to playing. I have submitted the question to B&O support. I will revert back in this thread with what they say.
Shall add that if I put everything in stand at and then start up again it does not work to change channel again.
Update: B&O support informed me that an update was triggered for my BS1 to cure the problem. 2.1.51694 is now in BS1 and I can change channel as I used before ?
@Hiort
Was that an update just for your BS1 or is it a general one?
