BV10 subtitles problems
I have subtitles on my BV10 which I cannot turn off, any suggestions ?
I have looked at the menu but not found a solution.
I assume that you are using the digital tuner.
On my BV10 I press MENU 2 (for Subtitle Language) and then select subtitles to off.
Hi Guy, when I press menu I get the following in the photo. When I try open any options I get nothing. Yes I am using a digital tuner.
That looks to me as if you are using an external set top box. If so, the subtitle settings may well be in the menu of that STB.
