BV 9 and projector
Hi! I have a problem with loudspeakers connected to BV 9. If use with projector only loudspeakers on tv and subwoofer work. Immediately when format in beo4 is pushed twice and picture shifts to projector front speakers (beolab 8000) will cut off. Any suggestions?
hi! you must also configure the speakers in cinema mode. (roll, distance, volume, etc.) so switch to cinema mode (format 0) and go to the bv9 (bs3) menu on the cinema screen. beoandy
Thanks, of course :) Works fine now. Ipe
