BV 11-40 mk4 turned black
Hi forum My Beovision 11-40 mk4 suddently one night turned black. I was using the build in Youtube-app. The sound is still there when I use the tv-tuner. Also when I turn on the television (when there normally is "Bang and Olufsen") there are light in the screen. You can see the backlight at the screen as I understand it. Anyone who know what to do or is it just trash?
Hi, I have the same problem with my Beoplay V1-40 which is basically the same TV just in a different skin. Did you find out what the problem was with your TV?
if you have the MK1 of V1-40 it is a very troubled tv. The BV11 is more stable. But no, I did not found out. Wating for someone in here to answer. My lokal B&O repair is sure too expensive.
