BV 10 - 40 Fan operating temperatures
Hi all, I have lost or misplaced my engineering menu notes, I am looking for the fan operating temperatures   ---   ie on and off, I realise I could do a factory reset, but, not sure if that would reset other parameters of the tv!
Is this what you need? (from the 'Fan Adjustments' section on page 4.9 of the service manual): In this menu, the following settings can be made: Fan full speed temp 45-64 Fan stop speed temp 36-50 Fan PWM min. 16-39 Fan PWM max. 20-41 The following can be read out: Fan 1 speed 2057 RPM Fan 2 speed 2002 RPM Temperature 1: 42c Temperature 2: 24c
Yes that's it, but I was looking for 'recommenations' for the settings.
