Beovision7-40
I have a Beovision 7-40 - Type Number : 9351 . Can anyone tell me if this is a HD TV>? Thanks Noel
Hi, Depends how you define HD. It has a 720p panel (HD) but not all of the type 9351 had HDCP. However, the lack of HDCP can be bypassed by adding a cheep HDMI splitter which are known to removing the copy protection. So, you got HD resolution over the DVI input. But you might not have HDCP compatibility which is required to make it so called 'HD Ready'. Edit: No HDMI by the way...
Thanks for the info Ravsted. Much appreciated.
