Posted March 16, 2024 at 18:04 GMT
The rationale that I've seen - this was posted (albeit caveat'ed by his not being involved) was that the vast majority of users nowadays just use internal sources plus perhaps one peripheral (a set top box, or Apple TV).
Given this rationale, and the fact that my installer had spoke to Denmark a few times around release time, and was told to forget about matrix integration, that it would never happen - all lead me to forget about it.
I'd have been more upset by this if my setup was more complex, as it would be a real impediment. In my simple case, its ok - moving my secondary / tertiary sources to my main living room cabinet was ok. I primarily have the matrix to avoid having any perhperhals in my bedroom, and I can survive with the matrix passing through the still matrix connected SKY Q straight through to my bedroom. Anything else in my bedroom, I just use the internal LG streaming apps.
But it is a pain still - not sure where you are based, but SKY won't give you two UHD capable boxes, as the Mini secondary box is not UHD - so a matrix was the only way to get SKY in UHD to all rooms. All a bit of a mess really.
Your way out may be (ask your dealer) to get a BeoLiving Intellingece (the Gateway replacement), as this may be programmed to speak to the Atlona and change the connected source it sends to each Theatre room. I have a feeling that that may work - but check with your dealer. As such, the BLI could have defined scenes to get the matrix to input select for you, and those may well show up on your Beoremotes,
