Beovision Eclipse Manuals
Dear all, I am the "proud" owner of an Eclipse 55" that needs OLED screen replacement.
Of course I got an offer from a B&O dealer for the new panel and the related work to do the installation, but I have that insane itch of "doing it myself".
So, aside buying the new OLED panel, does anyone possess the Eclipse TV installation/maintenance manual to get the necessary explanations on how to dismount the old panel and install the new one?
It seems that user manuals are easy to find, but maintenance is like the holy grail of secrecy.
Any help or link will be highly appreciated.
Thanks a lot in advance.
Kind regards
My Eclipse got a new panel under warranty.  I watched the repairman do the swap.  I would not attempt unless you have specific instructions.  It wasn't just taking off the old panel and putting on the new one.  It was taking off the old panel, swapping a bunch of parts from old to new, and then puting the new panel on.  I mean none of it looked too difficult - no special tools, just a screwdriver / maybe a torx wrench and removing / adding the panel is 2 person job lifting and centering, However, knowing which parts need to be swapped in which order would probably be hard to figure out and easy to miss something.
