Beovision 9 parts
I am looking for an ACM (automatic color management) camera and cable for a Beovision 9.  Does anyone in England or Denmark have any parts.   Thanks.   Art
I have  a complete frame with ACM taken from my BV9 2 years ago. It has the black colour.
Beobuddy ,   where are you located?   I have a brand new black frame. It said ACM on the crate but no camera.  Only the cut out in the frame to install one.  Would you sell me just the camera and the attached cable? Art
Hi Guys:) The same story... I need ACM to my broken BV9. @Expoman - did you found this part? or do you know, who can offer it?   @Beoboddy - Have you got this ACM part for BV9?   Will be thanksfull for the answer:) Best regards Konrad
I am a happy owner of BV9 and BL5, completely addicted to their form and image and sound reproduction.
Hi, Here also. Camera is there but don't want to move:)
@Ipe:) I have exact the same problem - I can see the "greyscale bar" but camera is dead. I chacked - the engine insidew of the module, and it's ok, and very small voltage is coming to the engine, when I'm asking in menu about ACM, but I have only this greyscale bar. The same when I'm turning off the tv. I was in contact with B&O serwice in this case 2 weeks ago and it was suggestion from them to contact coutry dealers or services. Finally it was not effective - in Poland we have 3 of them, every each is sure this part (as separate ACM module) is out of sale. Let me know, please, how the situation looks like with your BV9, and if you will find the way to solve the problem:) My plasma screen is getting more and more "yellow", so needs ACM action for sure. Will be thanksfull for your comment:) Best regards Konrad
Hi, My tv also have just that grey scale bar and the camera stays in its hiding place. Luckily picture is still quite ok. That ACM module - is it possible to take it out and fix. I suppose it manmade:) So.....? Tried to check after service manuals for BV9 but did not find any and if anyone have that module as extra there are several of us who are interested.
Yes, I took it out (attachment - pictures), and checked the micromotor. Problem is, that the motor is working, so it have to be something with electronics, and I'm not a specialist/... Maybe somebody know, how to fix it? When I'm sending signal to TV thru remote to make ACM action, I have 3,65 Volts going to engine, but nothing happend :( Any proposal?
Yep, came to same thoughts. Took that out also some time ago. Can it be some software problem? Did you try to reset the tv? I'll do it today. Sometimes the way of the bits is just waiting someone to do that:) Actually I sound like me calling to online help. "Good morning. I have some problem with my........." ......aaand before you end your question....... "Did you take the mains cord off? Did you push the reset button? Did you start your device again?" etc. Only 9.90 / minute. For members -20% :D There are few of these BV9's for sale at quite reasonable price but far away from here. Should buy a ferry ticket for a driver (me) and for the van:)
:) And how about resetting the TV in your case? It was succesfulkl? Do you know the procedure for restoring the TV to factory settings? Where is the RESET button?
