Beovision 7 55 - Airport Express
Hi, I have a BV 7 55 MK2 with BL7-6, Bl 8000 & BL 6000 & Besound 4 I wonder if I can listen my musics thru airplay without turning on the TV. Before buying the TV and audio, I used to connect my airport express directly to my BLs' line in socket, so I didn't have to turn on any devices beside using my iPhone. As turning on TV is quite bothering, I hope there is a solution.. At least, I hope that I can turn the screen off (usually I listen to music when I'm in bed..) If I have to, I'm willing to buy extra devices   Thank you for your advices guys!
Have a look at this: https://shop.oneremote.dk/shop/69116-powerlink-aux-adaptor/4154-powerlink-aux-expander/ Although I have no experience of this device, it seems to do exactly what you require.  I have used other OneRemote products in the past and have been very impressed.
Thx a lot! I've ordered it
Would a BeoSound Core work in this mix? I’m trying to do the same - BeoVision Avant Powerlink to BeoAmp 2 ceiling speakers. I will add a BeoSound Core in this mix for Airplay and other music sources. When I press Airplay to the Core, where would the sound come from?
