Beovision 7-40 Speaker Converting to Wifi / Bluetooth
I was looking for help on how I could covert a speaker to either bluetooth or use via wifi, I am in AUS and wanted to know how you can do this?
Hi Lawso, 1) What do you prefer; a) to have an external device to add streaming capabilities, or b) an internal integrated solution? 2) To which B&O model would you like to add these capabilities?
Hi Lawso, Yes, I can help! Please purchase either Apple Airport Express, Google Chromecast Audio, Audiocast M5, Tibo Bond Mini or any Bluetooth receiver for wireless music from your phone to your B&O Beolab 7-x or Beolab 10 TV speaker (sorry I don't sell these devices, only the cables!) When used with any of the devices listed above, your Beolab 7-x/10 speaker needs a special powered cable to generate the trigger signals to activate it:- https://soundsheavenly.com/line-in-connection/102-438-minijack-to-beolab-2-7-10-2500-powered-trigger-kit.html#/2-length-1m In this configuration, the music player will control the speaker volume, but the speaker will remain on all the time that the trigger cable is connected and powered on. Kind regards, Steve.
@Steve Great comment Steve. How does the (for instance) Apple Airport generate a trigger signal for the BeoLab?   By the way. Is it possible to see the linked product when your website is temporarily closed? I understand your not 24/7 available to follow-up on everything. Though I can imagine that you keep all informative parts of your website accessible, and close ordering and contact form. Would that work for you?
I wouldn't discount a Playmaker. You can pick these up quite cheaply second-hand and they of course have built in trigger for Powerlink speakers via an RJ45 to PL cable.
Hi, Sure, the Airport Express Express doesn't generate a trigger signal, so my cable provides this.  Here are the details of the cable (you can see full information when my site opens tomorrow morning):- Kind regards, Steve.
Get an Hall audio WiFi streamer and you will have Airplay2, Bluetooth 5, Spotify Connect, DLNA and you can connect your whatever TV via HDMI input (ARC). It also got a powerlink socket with trigger signal built in for Beolabs. https://hallaudio.com/en/produkt/traadloes-streaming/hall-wifi-streamer/ Hope this helps Stefan
@Steve Very interesting the Mini-jack to RCA cable also has a trigger signal. But for my understanding, the trigger signal needs to be 5v on Pin 4. Where do you get the 5v to be used on Pin 4 to activate the B&O speaker amp to get from stand-by to active? Hoe does that work with this cable?
Beofan for many years with a penchant for 1990s audio systems.
Of course, I understand its Steve's business.  :-) But I do not have to know how the cable has been configured internally. I just want to understand if this is only a Mini-Jack-to-DIN cable ... Or that it comes with something else for the 5-volt/trigger signal. @Steve: maybe you like to respond to this?
