BeoVision 7-40
I have a Beo-Vision 7-40 and the TV wont turn on, I have tried to bypass the beo sound bar and do a direct connection, there is no standby light and the CD tray wont open, does anyone have any idea's what may be wrong?
Have you checked the fuse in the mains plug (assuming you are in UK)?  Or maybe swap the power lead with another device in your home and see if this works.
Have you tried to play a DVD in the Blueray player? What kind of sources (like cable-TV) are connected to the tv ? Can you go into the menu of the BV?
