Before I go spendign money on any useless adapters or cables, I'm hopign for some advice here.
I want to take the Beovision 8-40 out of my office and replace it with the Beovision 7-32 I had stored away unused for a while. I know it's older, but it looks so good, and I have just managed to get hold of a motorised stand for it too.
Of course the BV7-32 has no HDMI inputs. The nearest it has in a DVI-I, so I bought a cheap HDMI-DVI-I adapter from Amazon to test it, and connected my Google TV device to it. I then set AV2 up as 'PC' in the connections menu, and switched the HDTV option to 'DVI-I'
I got a picture from my Google TV but it was poor, and had lines across. I unplugged the adapter, plugged it back in, and the picture disappeared completely - it's a cheap adapter I bought just to test it, so probably juts poor quality.
So, this is what I want to connect to my Bv7:
- Google TV
- Nintendo Switch
- Nintendo Wii U
All of these would normally be connected via HDMI, but as the BV7 has no HDMI inputs, I am not sure what to do!
I did wonder if the best option would be the Beosystem 3 Mk2, as that has 2 DVI-I outputs and 4 HDMI inputs, but I am not sure if a Beosystem 3 and a Beovision 7 will play well together? Would they both be trying to respond to the same Beo4 commands?
Another option is to buy a better quality HDMI to DVI-I adapter, but one that also has audio connection, as I had forgotten - DVI-I doesn't carry audio!
I also see that HDMI to YPBPR, and also HDMI to SCART adapters are available, but I am assuming they would not give me a 720p input.
Any advice would be much appreciated. The BV7 TV may be nearly 20 years old but it still looks great, and it would be a shame not to make good use of it.
