I guess it would involve some metal cutting in the bottom of the pole, but what about the attachment of the pole to the rotating mechanism?
Thanks in advance
When upside down you will see an opening (hole), possibly covered by a sticker. Rotate the stand on its base until the hole lines up with the pole and you will see the four screws. As you can see in my photo, there is usually a DIN connecter within the pole to lengthen the motor control cable for the floor stands.Great info when tI'm going to take it appart.
Have a look on the back of the BV26 Service Manual. This has diagrams of all the stand options with Type numbers. However, I can’t recall ever seeing one in person!Yes I found that diagram when you first posted the type number. But might not have been a very used stand option judging by the lack of pictures of this setup type.
